Page 2 of 2
Re: RB has eaten an IWIS chain in only 190 miles.
Posted: Thu May 27, 2010 10:27 am
by pasner
I know that Arkatxu bought the IWIS chain from a very known German dealer, so Im completely sure that it is not a fake chain. I have the same chain on one of my lammys and no problem at all. Probably aligment is the problem on here, but could be another reason for this problem?
Posted: Thu May 27, 2010 1:14 pm
by ArKaTxU
mouse wrote:
ArKaTxU wrote:Hi.
I have a RB20 and after 100 miles I hear a strange sound in the chain side of the engine.
Today after 190 miles I open the engine and see that the chain is very stretched and I can put the fingers down and the chain can touch the engine case in the up side.
The chain is a IWIS 81 links.
This is not very normal, not?
What can cause this? bad chain?
Thanks for your help!
The GENUINE iwis chain would only stretch and become useless after about 30,000 miles, MBD have never had a failure with a GENUINE iwis chain which is why we stock them.
Like pasner says, my IWIS is from a know German dealer, and is GENUINE.
If you want you can see the "FIRST IWIS CHAIN IN THE WORLD THAT STRETCH AFTER 190 MILES" in Gijon, i will be very happy that you look, and tell me if is a GENUINE or not.
Or maybe i can put it in ePay because is a very strange item :mrgreen:
There are very good shops that sold GENUINE items and not FAKES.
Posted: Thu May 27, 2010 1:19 pm
by ArKaTxU
stageman wrote:same happened to my brand new IWIS chain on a TS 230. dealer told me they stretch when in use from new and to just tighten it again. was reluctant to do so but had no other chain, tightened it up and kept it, however controlled it regularly. there was no further stretching discernible so guess it´s just what they do in the first couple miles and then they stretch no further. it is still in the motor.
The problem is that if I put a finger down the chain near the crownwheel and other one near the front sprocket, I can touch the engine with the chain, then if i tighten it again still is stretched.
Thanks!
Posted: Thu May 27, 2010 4:41 pm
by MarkH
What size sprockets ya got?
Did you count the links on the chain to make sure you actually had an 81 link?
I just pulled an 81 link from the shelf that was actually an 84 link so count those links.
Posted: Fri May 28, 2010 12:55 pm
by ArKaTxU
MarkH wrote:What size sprockets ya got?
I have 47x16.
Was a possibility that wasnt an 81 link, but i have count the links, and when i put in the engine when i rebuild, the chain looks good.
Cheers.
Posted: Fri May 28, 2010 6:12 pm
by Supereibar
Arka melón a ver si aprendemos a contar joder...
Posted: Fri May 28, 2010 6:15 pm
by ArKaTxU
Supereibar wrote:Arka melón a ver si aprendemos a contar joder...
hahaha hijoputaaaaaa!
que soy de ciencias, gay!
Posted: Fri May 28, 2010 11:02 pm
by Supereibar
:lol: ;)
Posted: Sat May 29, 2010 6:26 am
by stageman
Thanks!
Sorry, not sure if I get this correct. Are you saying that the chain is now too far stretched so that it rubs on the casing ? Maybe a Variochain will help to take up the slack, see
http://www.lambretta-teile.de/Kettenspa ... -Lambretta
If that doesnt help then you´re looking at larger sprockets. Buying a new chain would probably only repeat your problem.
Posted: Sat May 29, 2010 9:01 am
by ArKaTxU
Thanks!
Hi stageman.
Yes, you understand well (sorry but my english is very bad :( ), the chain is now too far stretched. I know the Variochain, but i will buy a new chain and must check the crownwheel and clutch spider.
Thanks.
