Page 2 of 2
Re: imola tuning by mick abbey
Posted: Fri May 28, 2010 12:54 pm
by J1MS
RG 500 bearing, if you do later stroke out the motor to 60mm a recessed head Either stepped or doweled would be best IMO
But I think Mick would be best placed to advise, I like the fact he's kept the transfer timings low looking for more port area with aditional ports and widening the original transfers.
Posted: Mon Jul 19, 2010 3:38 pm
by rocho68
hi guys , got my baby running but havin trouble with the jetting , starts first kick but as you try and ride through the gears she splutters and pops then if you wang the throttle back she takes off like a rocket , any ideas ?
Posted: Mon Jul 19, 2010 6:53 pm
by rocho68
forgot to tell you , av 268 atomizer , 125 main jet ( tried 135 and 145 ) 55 pilot and x2 needle (when it says set on 2 clip is this from the bottom of the needle or top ? help !!!!!!!
Posted: Mon Jul 19, 2010 7:32 pm
by col265
rocho68 wrote:forgot to tell you , av 268 atomizer , 125 main jet ( tried 135 and 145 ) 55 pilot and x2 needle (when it says set on 2 clip is this from the bottom of the needle or top ? help !!!!!!!
I'd say 2nd clip is 2nd from top. Try an AV266.
Posted: Mon Jul 19, 2010 10:50 pm
by drunkmunkey6969
Do you run an air filter? 125 sounds small, and as Col says try 264
Posted: Tue Jul 20, 2010 6:32 am
by rocho68
hi dan , its not running an air filter , with the amount of tuning i would have thought it would need a bigger main jet too , what sort of base setting would you start at and would a different pilot make any difference ? looks like i need to get it up to you to get it set up correct !!!
Posted: Mon Jul 26, 2010 8:53 pm
by carlos fandango
I saw this scoot in the flesh at the "summer session" and it looked amazing, 8-) loved all the subtle modifications ;)
Did it win anything ?
Posted: Tue Jul 27, 2010 10:22 am
by Special X
Try an X13 needle on 2nd clip.
Posted: Tue Jul 27, 2010 6:49 pm
by soullad
J1MS wrote:RG 500 bearing, if you do later stroke out the motor to 60mm a recessed head Either stepped or doweled would be best IMO
Aye, have always thought, amongst other things, that transfer timings around 125 deg help promote a torquey set-up. Probably helps with encouraging scavenging and maximising the blow down time.
Posted: Tue Jul 27, 2010 8:55 pm
by rocho68
carlos fandango wrote:I saw this scoot in the flesh at the "summer session" and it looked amazing, 8-) loved all the subtle modifications ;)
thanks carlos , heres how i made the disk brake cover and rev counter holder !!!ImageImageImageImageImageImage
