Best hydraulic disc brake.
Ihateyoubutler
Thanks for the help.
eibargum
Go for the Scootrs one [not anti dive] keep it simple, only weak spot is the speedo drive, change it for a Steel MB jobby before you fit it and you wont go far wrong :D .
Frautzi
I have the Anti Dive RS but as yet its not fitted, can you just not fit the tie bar and use it as is with MB springs?
Frautzi wrote:I have the Anti Dive RS but as yet its not fitted, can you just not fit the tie bar and use it as is with MB springs?
No. You would need to change the plate that holds the caliper so that it can locate into your fork links as a standard drum or disc hub would. This part is available from www.justlambretta.com
Frautzi
^^ ok thanks soulsurfer...
Jay
Mel K
Here's a pic Steve, not the best but I'm not David Bailey :bald:
LambrettaSX
soulsurfer wrote: I think the German LTH/Worb designs have the antidive/looks edge, the LTH use crap callipers but these can be changed to Nissin;
How can you tell it is crap? Did you have bad expirience with it?
We sold more than a hundred brakes and never heard of problems with the caliper.
I tested it 2 years before going on sale in the EuropeanScooterChallenge and even in a race on the Nuerburgring without problems.
If there is one with yours please send it back and get it exchanged.
We take this very seriously as it is important that this item works all the time.
Marco
LTH
BTW: I won't change to Nissin calipers if the only proof that it is really Nissin is the writing on the caliper.
"the later you brake, the longer you drive fast"
Hi Marco,
It was well publicised on the forums some years ago of the same calipers having pistons siezing in the early ScootRS ones and I believe various people then made stainless steel pistons to fix the problem. This was why ScootRS changed to Nissin, no offence but they've sold many many of their brakes and I know they're very reluctant to change design.
GP Kevo
I think Frank Sanderson does an anti-dive kit for the ScootRS brake?
sydduckett
This is a no brainer go for the PM and steer clear of Scootrs, there anti dive doesnt even have bushes.....cowboys and all that.
