Page 2 of 2
Re: Hydrolic clutch
Posted: Thu May 20, 2010 6:49 pm
by carlos fandango
Re: Hydrolic clutch
Posted: Thu May 20, 2010 8:59 pm
by Fux
How`s that been treating you carlos?
Re: Hydrolic clutch
Posted: Thu May 20, 2010 11:28 pm
by carlos fandango
Fux wrote:How`s that been treating you carlos?
So far so good, its off the road at the moment ( not clutch related
) Its in a rb200 and its a four plate clutch with strong springs. I wouldnt say it was a two finger operation and not as light as i had hoped
but lighter than before
Re: Hydrolic clutch
Posted: Fri May 21, 2010 6:03 am
by Fux
Well, mine is a 2 hand operation at the mo....
What make was it, looks like I could set one of those up pretty easily. I like the fact that its easier to take the engine out.
Re: Hydrolic clutch
Posted: Fri May 21, 2010 11:27 pm
by carlos fandango
Fux wrote:Well, mine is a 2 hand operation at the mo....
Its a magura hymec from Venhill about £70.00 a quality product. they do various ones the only problem with them is that the travel on them is only about 10mm so you need a way to adjust them to get it in the right position.
An easier solution is the hebo ones that come as a kit
http://www.trialsbits.co.uk/index.php?cPath=79 (the universal ones in the photo, but look out of stock) this is part cable operated so the slave cylinder can be fitted anywhere
Russ
