Lighting Problems No Front Or Rear Lights,
Treeman
Main scooter: GP 225 TS1
Hi, I’ve got a similar problem, front lights working rear and speedo have just stopped working.
I have changed the headlight bulb holder (as I thought that it was the problem) but with the new one it’s the same.
All connections in the bulb holder appear to be good. Would I be right thinking that it could be the ignition switch or the lights dim switch. I don’t have a multi meter to check power in connections etc.
Thanks!
Treeman
No comments. So, I’ve wired the lights so they're on all the time, taking a wire from the brown to the second black down on the light bulb holder. I always ride with the lights on so it’s the same as always in a kind of way. I think it may be a problem with the ignition black wire, any comments?
Thanks
mick1
Main scooter: Li Avanti 225
PM sent
