Page 2 of 3
Re: knocking noise on scoot rs anti dive
Posted: Thu May 13, 2010 10:35 am
by soulsurfer
Steve, that's not the case with anti dive, that lug isn't used. I'm using disc links, if using drum links, the lug on the link has to be removed so the caliper plate can rotate. It's then held by the tie bar to the fork leg and the assembly then pivots on the spindle and tie bar like a parallelogram within suspension travel.
Posted: Thu May 13, 2010 11:52 am
by red ghost
soulsurfer wrote:
Is this the Worb5 unit?
Posted: Thu May 13, 2010 11:57 am
by sean brady scooters
one thing to watch out for,is spindle nuts (especially domed or pike ones) hitting shockers..
Posted: Thu May 13, 2010 1:06 pm
by sydduckett
Gaz, i told you that by buying of Randle and saving a few pence you would be looking at a false ecconomey....
Now Ill tell you again stop buying ting tong rubbish.
By the by if you wanna pop over and pick up the end can tonight no worries, swapped some rings with JB for a 2nd hand one yesterday and fits like a glove....
Posted: Thu May 13, 2010 1:08 pm
by shocky
soulsurfer wrote:Steve, that's not the case with anti dive, that lug isn't used. I'm using disc links, if using drum links, the lug on the link has to be removed so the caliper plate can rotate. It's then held by the tie bar to the fork leg and the assembly then pivots on the spindle and tie bar like a parallelogram within suspension travel.
ok i understand cheers for putting me right i dont have any knowledge of these brakes but that makes sense as that will allow both sides of the hub to move slightly when the brake is applied
Posted: Thu May 13, 2010 1:22 pm
by soulsurfer
red ghost wrote:Is this the Worb5 unit?
Yes. Not cheap but superb solution with quality and looks IMO.
Posted: Thu May 13, 2010 7:58 pm
by red ghost
soulsurfer wrote:red ghost wrote:Is this the Worb5 unit?
What worries me is how does a 'Dirty Sanchez' fit into it?
Posted: Thu May 13, 2010 8:06 pm
by soulsurfer
God knows
I did ask if I could have it without the engraving
Posted: Fri May 14, 2010 12:38 pm
by sydduckett
How much is the worb anti dive and will it bolt staright on to a scootrs set up?
Posted: Fri May 14, 2010 2:00 pm
by soulsurfer
sydduckett wrote:How much is the worb anti dive and will it bolt staright on to a scootrs set up?
It's a complete kit that requires some donor parts, it's not an upgrade kit and isn't compatable with any other brake setup except maybe some parts of the LTH brakes.
The SIP caliper additional.
