Page 2 of 3
Re: Anyone seen mis-machined 200 casings....
Posted: Wed May 12, 2010 1:35 pm
by sean brady scooters
I agree carlos
Posted: Wed May 12, 2010 4:48 pm
by dirtyhandslopez
Drill new holes in the plate, not the case :ninja:
Posted: Wed May 12, 2010 9:13 pm
by camel
dirtyhandslopez wrote:Drill new holes in the plate, not the case :ninja:
how?....how do you redrill the correct centres from blind holes???
Posted: Wed May 12, 2010 10:10 pm
by J1MS
I havnt had an engine case, yet, where the stud holes were out of line.
But I don't use the steel oil seal plate either. I prefer the much out of fashion alloy oil seal plates, which seem to be pretty reliable if someone hasn't already beaten it out of shape.
Posted: Wed May 12, 2010 10:37 pm
by joeythescooterboy
Take a rubbing from the case and use it as a template.
Posted: Wed May 12, 2010 10:49 pm
by RICSPEED
I think you need a drive side bearing with a seal on it but remove one seal so that it still gets oil to it but still seals even if the plate is out of line
Posted: Thu May 13, 2010 4:50 pm
by shocky
RICSPEED wrote:I think you need a drive side bearing with a seal on it but remove one seal so that it still gets oil to it but still seals even if the plate is out of line
i think that it was thought that a sealed on one side bearing wouldnt allow gearbox oil to lubricate the drive side oil seal and was a bad idea :?:
Posted: Mon May 17, 2010 10:13 pm
by Chutney Brownlove
carlos fandango wrote:
Knowledge wrote:Can you not rotate the oil seal retaining plate by 45 degrees, and drill and tap new holes?
Wouldn`t this cause you to break through the casing to the sprocket side ? as where the screws go the casting is thickened up to allow for them.
Posted: Sun May 30, 2010 7:52 pm
What's the secret?
Posted: Tue Jun 01, 2010 5:32 pm
by soosh
Chutney Brownlove wrote:What's the secret?
Looks like its just guess work rather than fact then.
