Engine mounts
mr series 2
Main scooter: LI 150 Ser 2
Has anyone got any advice ref engine mounts ive just built a new 200 engine only mildly tuned i used genuine sil engine mounts fitted in the correct position as per stickys book but after just 295mls the o/s one has completely collapsed & the rubber has broken away from the metal :cry:
minotaur
i was having the same problem and bought an extra long mount and bolt from andy francis
the problem, i now realise, was caused by worn engine mount cones, it might be worth replacing these first and then buying mounts from a reliable source like scooter restorations
must say though handling is great with the extended mount
I did the same and bought new cones as well at the same time
mr series 2
Thanks to both of you for the advice the mounts that failed came from MB so would expect them to be genuine sill i will check the cones when i replace the faulty mounts i do like the sound of the extra long ones from Andy Francis i will check these out thanks again
    Users browsing this forum: Amazon [Bot] and 2 guests
