Lammie hydraulic (did I spelled that right?) disc brakes..
yes the DACTEK wheels are totally seperate items so can be fitted without fitting the other one :)
Dryballs
I had a ScootRS disk on my TS1 before upgrading to an LTH antidive - which is great!
I also have a ScootRS one on my GP in New Zealand
and I have an original disk with hydraulic conversion which I'm going to use on my series 1
The scootRS brake was great, but dove horribly - even with stronger springs (all this does is give you harder suspension!) because the first action of the brake is to wind up the fork link. You dont get any feel for what the front wheel is doing until the suspension has dived fully.
I wouldnt buy another disk without antidive - it makes the brakes so much more useable and progressive
And good spelling btw... good to see us foreigners spelling english proper!
Supereibar
Aren't you a kiwi? In that case you have no excuse my friend... :frog: :frog: :frog:
One question, since Sean has not seen my question, what is the LTH brake?
sorry jamie....
this one on the racer.. :D
http://drunkmunkey6969.googlepages.com/trackracerts1
damdam
...and this is LTH webshop:
http://www.lambretta-teile.de/
