TS1 gearing
FREE tuning and maintenance info, plus links to our original tuning pages that started it all off.
2bobscoot
Main scooter: gp225ts1
Advice please
Running a Ts1 225 with a JL4 curly pipe, Li 150 gearbox, pwk 30mm carb.
Acceleration in 1st 2nd 3rd is fantastic , 4th gear and it will not accelerate at all until I’m going down hill. Not sure of the sprocket arrangement will check that out this week. I have a spare JL3 also aGP 200 gearbox, but don’t really want to swap out the gearbox as it is fine in the first 3 gears. Any advise welcome
holty
Main scooter: lambretta gp
at a rough guess your front sprocket is too big, go down 1 tooth and road test it, should then pull in 4th gear
ricalnic
Main scooter: Lambretta GP Monza 225
Or try another exhaust if you can, which might not be as peaky as the jl4. You may find another exhaust makes it more enjoyable to ride than chasing the revs with a jl4
Holty has it right, drop a tooth on the front sprocket. MIne was similar to yours with 17/46 sprockets on an Li 150 box, it was embarasing. Totally transformed when I dropped the front sprocket by one tooth. That was with a JL3 which I found to be rather limiting on top speed.
2bobscoot
Just checked sprockets found to be running 18 -47 final ratio of 4.44 . 17-47 would take it to 4.7 or should I go 16-47 and run it at 4.99 ? I do have a spare 46 tooth?
garry inglis
4.99 will work great
garry inglis
Options Image
Sent from my SM-G960F using Tapatalk
garry inglis
that turned out crap
2bobscoot
Thanks anyway 👍
    Users browsing this forum: Ahrefs [Bot] and 2 guests
