Vespa gears
Daggs
What are the symptoms of a worn or damaged cruciform on a Vespa gearbox?
Can it cause difficulty in changing gear?
mick1
Main scooter: Li Avanti 225
usually slipping out of gear (3rd tends to be worst)
With difficulty in changing gear i'd be looking at cables, clutch and selector box,
tony172
Main scooter: vespa t5
In my experience it's usually clutch
gaz_powell
Agreed with above, if it were me i'd check the selector parts before you open up to look at clutch.
Selector box top off, check cables, then whip the selector box off check its all okay, then the rod that connects selector arm to cruciform.
Good luck
Scooterindo
Main scooter: Cutdown Bitza
How old is the scoter ?? Occasionally a new selector box with stiffer springs and sharper cut selector arm wheel was all it took (after id already replaced the cruciform doh!!)
Old Skool Cool
    Users browsing this forum: Ahrefs [Bot] and 40 guests
