TS1, Avanti ex box, VHSH30, kytronik curve c, boyesen reeds,
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
hendy
Touring tuned, steel lined TS1 with avanti ex box.Image
Sent from my SM-A520F using Tapatalk
Scooterdude
Just commented over on lcgb, but also bare in mind there are discrepancies between dyno’s mine saw a 3hp difference from MB to Chiselspeed’s machine and Martin admitted in one of the scootering articles a while back that his roller is worn smooth.
holty
Main scooter: lambretta gp
does seem a little low on max bhp although torque looks good, I think this may be down to the pipe, I suspect an expansion exhaust would release a lot more power, as to figures mine did 34 bhp on martins dyno then a few months later 35 on darrells dyno so its pretty accurate.
hendy
Yes, I expected a bigger number. More like 20bhp. However, it made 20bhp with a JL3 without any set up at all, just guessed jets. So maybe I was unrealistic?
By way of comparison, I had a tuned gt186 with bgm clubman that made 17bhp. Darrel Taylor's dyno for that one though.
holty
you said it had a touring tune, which will give more torque and not always more maximum bhp, which looking at your printout is very good, but it maybe that the port timings are more suited to a higher revving set up, are you using a standard reedblock and manifold, ive just fitted a bgm reed and stuffer to my mates, along with an mb manifold and it gave a boost in power, I did also enlarge the transfers and put a longer stroke crank in it to tame the port timings a bit.he has tsr evo on that , needs a bit of use to bed it in, but does go very well, will be going on martins dyno sometime in the future to get the carb set correctly
hendy
Bgm reed block. Boyesen reeds. Bgm 30mm inlet with built in stuffers.
I'm suspicious of the ignition. Thinking of trying it fixed at 18.
Muppet
i always run more advance on a box pipe than a expansion type on fixed ignition
C’est la vie
hendy
Muppet wrote: Thu Feb 07, 2019 6:22 pm i always run more advance on a box pipe than a expansion type on fixed ignition
That's 2 people told me that today.
19 degrees? I've got an avanti head, so it cools well.
Ignition could well be playing a big part in this as I've just been out on my Mugello 240 after making some ignition changes (static) as I was starting to think that the bike seemed to hit a rev ceiling that it couldn't go beyond. Sure enough, a change of CDI (strobed to same 17 dbtdc) now has the motor revving on considerably higher. This may be of interest to you as I also run an Avanti Ex-Box on this motor and was wondering whether the pipe was the limiting factor, which would have been odd as one of the key selling points for this pipe is the ability to rev-on beyond that of most other clubmans/super clubmans.
There are many factors that can introduce an ignition rev ceiling/limiter (e.g. LT coil, flywheel type, pickup, pickup alignment, CDI, etc.) but it is not uncommon to find that an advance/retard unit that retards too far can cause this. It's a balancing act as too much advance regularly becomes a limit to rev-on, with retard often allowing a motor to spin more freely and increase rev-on range, yet too much retard then goes back to not burning cleanly/fully and can become a rev limit again... making your motor feel rich and sluggish at higher rpm.
The good news for me is that my motor now revs and revs and revs, if I so choose to hold it to the higher rpm range, making it a viable pipe for many of the kits that other clubmans strangle.
Good luck getting it sorted.
hendy
Cheers adam. That's very interesting, especially as you're running an ex box too. It's a long time since I built the motor, but I really don't think it's an assembly issue; I kept notes, the squish is 1.2mm and I spent an age getting it 100% leak-free.
So, my thinking was to set it at 18 (maybe 19 as I've got a big head, CHT gauge and a clubman with big tail pipe) and see how that goes.
The only issue is that I need to get to a dyno for an objective measurement. I'm not keen on thrashing it yet as it's not even done 5 miles! For now though, I'm going to take it for a spin, tjen fix the ignition at whatever I decide and give it a back to back test.
