fuses
FREE tuning and maintenance info, plus links to our original tuning pages that started it all off.
nick b
Main scooter: gp200and rt195
Wed Dec 12, 2018 1:24 pm
I keep blowing fuses on my battery not immediately but every few days what is the highest ampage that is safe to use?
YAMLAM
Wed Dec 12, 2018 7:30 pm
wouldn't it be best to find out whats causing it, rather than trying to paper over it ? probably a wire shorting out. I think 8 or 10 amp fuse is the normal .
win or lose have a booze
nick b
Thu Dec 13, 2018 9:47 am
thanks it has been a wiring nightmare i keep soldering up the switch on the left handlebar but the gearchange seems to loosen it very quickly [so it could be that] it seems to only last about 250 miles it could have become loose again ,any suggestions of a solution to this problem?
nick b
Sun Dec 16, 2018 1:07 pm
I did what yamlam suggested even though the thought of removing my headset fills me with horror not only does it have the usual spaghetti it also has indicators 3 lights on headset an extra cable for fuel light it also has all the extra cables serveta decided to add for lights cutout etc .everything fine. I checked the full loom everything fine .the problem is it doesn't trip everytime which is always harder to trace about to give up when I felt the fuse holder was red hot ,it had been arcing out[wire loose]finally solved and repaired until the next time
Martin20
Main scooter: Lambretta LI 150 Special
Sun Dec 16, 2018 2:28 pm
Well done! Hope it's a permanent fix for you.đź‘Ť
nick b
Sun Dec 16, 2018 5:38 pm
thanks mate lets hope so but I have had lammys since 1980 and they will bite you in the arse when you are least expecting it
YAMLAM
Sun Dec 16, 2018 9:53 pm
well done for sussing it out.
l111amo
Main scooter: Gp186
Mon Dec 31, 2018 11:14 pm
Hi,new to this, I’ve just got myself a 200 lynx.posted elsewhere about it, are they 6 or 12 volt( mixed bulbs in at moment and no battery,ta
nick b
Tue Jan 01, 2019 9:12 am
mine was supposed to be 12v but after stripping it was 6v, after speaking to someone[all wiring diagrams say 12v] I was told the lynx was put together by every spare bit they had in the factory yours is probably 12v but don't be surprised if it isnt
l111amo
Main scooter: Gp186
Tue Jan 01, 2019 1:37 pm
Cheers/ will get a meter at the regulator when I get time
