Hello from Belgium
NEW MEMBER? - You must now introduce yourself here first BEFORE you can post in any other section!
Say hello and let us know a bit about you and what scooter you own, etc...THEN you will be able to post elsewhere.
Triumph
Main scooter: Lambretta Serveta li150 Specia
Hello,
Last year bought myself a Lambretta, seemed to be a Serveta LI 150 Special from 1980, scoot was quite original but had some problems with the engine (worn engine).
I replaced the piston cilinder and head and put a new clutch in been running without problems since.
Changed the 18mm carb for a 24mm and changed the 42mm clubman for a slightly bigger expansion exhaust, does 60 Miles/Hr for the moment on the GPS.
Took her to the VWD in Belfast and we had a great time over there, took her to Normandie for a week in August and had no problems at all. Will be going to the BVD next weekend and hope to see some of you over there. Also planning to go to Hungary WVD next year.
Regards Jurgen
Martin20
Main scooter: Lambretta LI 150 Special
Hi Jurgen, welcome to the forum.
Welcome aboard
johnny650
Main scooter: lambretta 64 li 150 Special
welcome Jurgen
