12V reg
Daggs
Is there such a thing as a regulator/rectifier for a Lambretta 12v conversion?
e.g. 12v AC from the stator into the Reg. Giving 12v DC out.
mick1
Main scooter: Li Avanti 225
Isn't that what the "Wassell" is ?
holty
Main scooter: lambretta gp
as above, wassell voltage regulator is what you want, i converted my ac stator to dc as well, to make it full dc, its working very well it the moment.
Daggs
Thanks guys, I've done some research and this seems to be just what I need.
Daggs
One other thing. Who sells them?
HxPaul
Try Anthony Tambs,he's on Facebook under Lambretta Tuning or Scootronics.co.uk
You can also get them off eBay but Antony is usually cheaper.
AUSSIE
To use a wassel unit you must have two wires coming out of your stator for ac power, theses are usually yellow, that plug into the wassel. If you only have one then you need a 4 pin regulator that makes 12 volt ac and 12 volt dc to trickle charge a battery.
Monty
AUSSIE wrote: Fri Mar 02, 2018 12:18 pm To use a wassel unit you must have two wires coming out of your stator for ac power, theses are usually yellow, that plug into the wassel. If you only have one then you need a 4 pin regulator that makes 12 volt ac and 12 volt dc to trickle charge a battery.
Or simply add the extra wire, you dont have to buy anything Special if you can use a soldering iron
mick1
Monty wrote: Fri Mar 02, 2018 7:58 pm
+1
Standard stator with one wire modified........job done
    Users browsing this forum: No registered users and 78 guests
