Kingwelle 64mm crank
hungdog
Anyone know if any alterations are required to the casings when fitting a 64mm crank ?
garry inglis
depends wich crank you use to how deep a groove is needed as some cranks big end runs insde the webs and others protrude
hungdog
Vespa Kingwelle 64mm crank for P2 more worried about web size and possibly having to machine cases to fit webs than worrying about the rod making contact.
Ginch
Main scooter: Vespa 150 Super
They are usually pretty quick to reply on Facebook, worth asking them.
hungdog
:ugeek: Kingwelle's reply
The motor has to be spindled up to 100.00mm , the crank diameter is 99.3mm
    Users browsing this forum: Ahrefs [Bot] and 48 guests
