lambretta 290 rotax
holty
Main scooter: lambretta gp
RManson wrote: Wed Nov 29, 2017 7:21 am Lookin' good Holty, but... what's the fan shroud for?
its only to cover over the flywheel, ive got an external pick up and trigger sticks out a long way, mainly as ive removed a lot from the flywheel, it will stop the pickup from getting damaged.
holty
RManson
Well... how did it go?! It sounds good!
holty
it seems to go pretty well, i do need to run it in before i dare to give it some welly, carb will need setting up, im sure it will be weak, so i will get it on a dyno to be sure, but first impressions are good.
garry inglis
Sounds nice that exhaust turned out well as well as the rest well done holty
holty
garry inglis wrote: Thu Dec 07, 2017 11:44 am Sounds nice that exhaust turned out well as well as the rest well done holty
cheers garry, yes exhaust does sound good, time will tell how much power its got, but its very torquey , its got a gt200 gearbox and 17 front sprocket, but it pulls very easy through the gears.
TED CRUD
Well done that man sounds mint looking forward to seeing a full test /Dyno run :)
Smash Ya Pastie
Washington Posse s.c
cartmel808
That sounds lovely... great work!
holty
after ryans piston melting problems with his rotax, it has been suggested that these big engines need a bigger stinger in the end of the exhaust so i have been altering my exhaust, removing the 26mm pipe and fitting a 30mm replacement
heres a few pics
ImageUntitled by stephen holt, on Flickr
garry inglis
How much louder has it gone has it got a deep rumble
    Users browsing this forum: No registered users and 31 guests
