Series 2 Handlebar
Geocamper
The throttle part of the handlebar is loose on my series 2. By loose I mean there's quite a lot of play side to side. Before I start taking things apart is there any parts that could be worn in this area?
cgt75b
Main scooter: lambretta
Hi
It probably just needs a few spacers between the olive and the brass gear change wheel.
Hope that helps
Cgt75b...................... :D
hendy
cgt75b wrote:Hi
Hope that helps
Except on the throttle wheel. :D
cgt75b
hendy wrote:
cgt75b wrote:Hi
Hope that helps
Oh s**t 4.00 am starts not good :D
Geocamper
Cheers Guys. The play I have is on the throttle side. Sorry for the vagness in my original post. I have now taken the grips off and I can see wear on the inner throttle rod. The rod inside has worn away which inturn has left play for n the outer throttle handle.
    Users browsing this forum: No registered users and 37 guests
