Having to change the rear bearing after 1000 miles did a 70 mile trip yesterday and noticed a bit of movement from the rear thought it was tyre pressure but on checking to mutch play for my liking
Mb rear bearings
- garry inglis
- Main scooter: ts1 230 and rb200
Is this the rear hub bearing or the gearbox bearings?
- garry inglis
rear hub bearing the middle part has give way i had about 5mm play top to bottom
- Main scooter: lambretta gp
thats a little bit annoying, you wouldnt expect it to fail so quickly, i presume box was shimmed correctly and filled with oil, you would expect that to be a quality bearing that would last a long time, have you contacted mb ?
- garry inglis
Yes shimmed correctly oil in I bought it off another dealer Christmas time it just started on this ride was doing a 30 mile stint on a1 as I say thought tyre pressure but when I got home got hold of wheel and didn't like the amount of play so stripped it thinking endplate nuts but all was ok apart from the bearing I have one in my rb with 2000 miles on that's ok anyway new parts on way
- GTFOMWSC
- Main scooter: GP230 Super Monza CS Tuned
Same here done 100's miles back in the 80's and never needed to change one now it seems I need to change one on every scoot I ever get.Maybe it was because I was used to just sliding around and thought that was the norm back then.
the man don't give a f@@k
- garry inglis
I wouldn't mind the original one I tapped out is still in good condition but if you put it all back together and find it isn't you'd well pissed
- garry inglis
all back together and no more wobble
- garry inglis
