dellorto si 24/24 mod
jum
hi has any one done the fuel bowl mod
want to know if you drill the 2mm hole at a angle or side ways and how deep
any info much appreciated
ducksta
1.7 mm streight
ducksta
It goes into a chamber behind so don't push too hard
gaz_powell
Follow the existing hole.
According to SIP you can open it up to 2.0mm on the P2 but from memory I only had a 1.8mm bit so used that just to open it up abit.
Are you putting the float bowl on with the 5.2mm valve?
gaz_powell
smiffy1968
Main scooter: Nevermind Mk1 T5
2mm hole all the way to bottom of main jet stack. Cosa bowl cover 5.2mm needle. Drill down to needle seat. I did 2.5mm all the way. Opened up fuel inlet too. 3mm bowl cover packer. Job done no fuel starvation issues anymore.
Sent from my SM-G903F using Tapatalk
hungdog
Or get the new pinassco 30mm carb
hungdog wrote:Or get the new pinassco 30mm carb
Is it released yet?
Is it released yet?
Aiming for last June, according to sites found by Google. :lol:
Yes that's why I asked...
    Users browsing this forum: Ahrefs [Bot] and 48 guests
