Air hawk cushion seats...
diesel
I'm liking your spare wheel mounted petrol cam MrG where did it come from? Timbo you won't be disappointed with the airhawk it's a great bit of kit.
Mr G in NYC
Main scooter: SX200
here you go , mine holds 4 liters one US gallon .
https://rotopax.com
G
diesel
Thanks
Timbo
Santa arrived last night with a seat... 8-) ..can't see any instructions on how to blow it up and more importantly what pressure, what do you reccomend?
diesel
Unscrew the valve and blow to inflate. Screw valve in to seal the air in. As for pressure you will be surprised by how little you will need. Inflate the seat and seal the valve,sit on it and carefully open the valve letting air out till you can barely feel the cushion or until you arrive at a level of air you're comfortable with. Less is more comfortable I've found. I'm sure there is a you tube video demonstrating this. Enjoy. And happy Christmas
diesel
Timbo
Cheers diesel.... 8-) .......will write a review once I get my scoot back from being sprayed... :D
Diesel is spot on with that advice, it will take a bit of getting used to but you don't want too much air in there or you will roll around and not reel connected with the scooter.
HxPaul
Timbo wrote:Santa arrived last night with a seat... 8-) ..can't see any instructions on how to blow it up and more importantly what pressure, what do you reccomend?
I hope when you finally inflate it,you dont find its a blow-up doll. :o Mind you I suppose you could still sit on it. :P
Muppet
about 2/3 full of air is about rite
C’est la vie
