Almost there, problems starting
tippo88
Sun Oct 30, 2016 9:54 am
Am almost there with my LI125 restomod full rebuild with gp crank,with SR alloy 185 cylinder and pwk 28/30 carb, scootopia ancelotti exhaust. Having some problems starting. It will only start and run for a short period if I have the throttle wide open. When it does run get smoke and oil out of the two joints on the exhaust leaving out deposit on the floor Obviously I need to fix The leaky joints, what's the best way to do this? Any ideas on what else could be wrong.
Thanks in advance
Tippo
Sent from my EVA-L19 using Tapatalk
bristolmod
Sun Oct 30, 2016 10:05 am
no idea on the carb set up but your comments regarding "smoke and oil" out of the exhaust joints is worrying. How much smoke? what type? How much oil? and again what type?
Scootering since 1968.
tippo88
Sun Oct 30, 2016 10:16 am
tippo88
Sun Oct 30, 2016 10:18 am
On floor
Morgan
Main scooter: T5 Vespa Mk1
Sun Oct 30, 2016 10:19 am
sounds like it's flooding......is the choke sticking, what size jets, etc
just seen the picture.......have you done a compression test ? could be a leaking seal
tippo88
Sun Oct 30, 2016 10:21 am
Yep did a leak test when engine was built but that was a while ago
tippo88
Sun Oct 30, 2016 10:50 am
So I guess do a leak down test to check its not pulling in oil from the chain case?
Morgan
Sun Oct 30, 2016 11:03 am
probably worth doing.......
Adam_Winstone
Sun Oct 30, 2016 8:59 pm
I'd look at changing the fuel as I've known people have similar starting + smoke issues because of contaminated fuel, which was straight from the local 'big brand' service station.
The other thin that I would look at is whether the float in your carb is sealing correctly as that much liquid in the exhaust makes me think that petrol is flooding through, which could also be a factor with the poor starting. If you are using a modern Dellorto, make sure that the float is not full of petrol. If you're using a Jetex, original Dellorto, or just about any carb (!), make sure that your float pin is home and not making contact with the float bowl as this can cause the needle to vibrate and not seal when shut.
Best of luck.
Adam
tippo88
Tue Nov 01, 2016 3:37 am
Thanks all hopefully will get to check out tonight
