Hi Shocky, thats correct, the RH switch is indicators and an engine kill (as per the wiring diagram in the SIL handbook) the L/H then controls the hi/lo and the horn, the L/H support looks to be the same switch shape as the std GP but scooter restorations believe it to be a different size aperture.shocky wrote:thats a servetaNorrie Bodge wrote:Best pic I can see here - http://www.topdeadcentersc.com/phpbb3/v ... f=2&t=3367
my understanding is that the left hand switch is the one that does the dip and main plus the horn like the original right hand side and the right handside is the switch that scooter restorations sell for the right hand side which does the indicators the side light and the main lights on but not the hi/low function does that help ?
One solution i have found is to use a Vespa GS, looks period and is simply drilled and tapped into the original gear support, dead easy to wire up and readily available at around £25
http://www.allstyles-scooters.com/acata ... 60096.html
