PHBH Slides between 40 and 45
storkfoot
Am I correct in assuming that you can't buy 41, 42 etc but it's normal to modify a 40 with a dremel to achieve the desired effect?
Angry Bloke
Thats what I'm just about to do Paul ,although as the difference between a 50 and 40 is only approx 1.2mm I was going to use a fine file to ensure the cutaway remains flat. :D
Is there any guide for how much to remove to achieve the different stages?
Angry Bloke
coaster wrote:Is there any guide for how much to remove to achieve the different stages?
Ive not seen one but I have a new 40 and 50 at home so was intending to measure and pro rata the results -
I will post the measurements when I get home ;)
storkfoot
That's the problem. You are dealing with a difference of 0.5mm from the base to the top of the arc. Therefore, it is 0.1mm you need to take off at the top of the arc to make it a 41. There isn't much scope for error!
storkfoot wrote:That's the problem. You are dealing with a difference of 0.5mm from the base to the top of the arc. Therefore, it is 0.1mm you need to take off at the top of the arc to make it a 41. There isn't much scope for error!
I don't know about a fine file, it sounds like a calloused finger would be rough enough.....some fine emery at least :?
Angry Bloke
It's less than I thought, the cut out on a 50 is 5mm and on a 40 its 4.1mm ;)
Lets say its a 1mm difference to allow some tolerance on my vernier
So presumably on a 45 its 4.5 , 42 =4.2 etc
As Colin says you could drag it across a 5 o'clock shadow and shave .1 mm off :D
I'll try some fine emery and see how it goes :)
warts
Main scooter: honda
When I was doing this with 36 PHF Del Orto's, I just turned a smidge off the bottom of the slide. This was dead easy and repeatable on a lathe with a digital read out. Which was just as well as I had two to do each time.
It was easy to detect the effect too.
Maybe the Del Orto manual has these dimensions, but I don't recall being aware of them when I was doing it.
storkfoot
Well about 10 or 15 passes with a small flat file, finished off with a very fine emery, and I have a noticeable leaning out of the flat spot I was trying to get rid of. Not completely gone but I am loathed to take any more off. With hindsight the original idea of a dremel would have been a disaster :-)
I'd modify mine with a phone, card and call to a Dellorto dealer. As stated, there is little room for error.
PS - The irony being that I modify Dellorto needles by hand so really am in no place to make such a comment ;)
    Users browsing this forum: No registered users and 32 guests
