Needles & Jetting with a Ramair
Bilko
Main scooter: LI150
What's weaker?
Running an X2 and wondering what to go to next as I'm on the weakest clip and still running rich.
I have X7 X6 X3
Bilko's Oily Blog
Bilko
Main scooter: LI150
From Cam Lam's site.
Leanest - X12 - X7 - X13 - X2 - X25 - Richest
So where do X3 and X6 fit in above?
Bilko's Oily Blog
Bilko
Main scooter: LI150
I went from the X2 to X7 and if I speed up gently it's ok, but if I pull anything more than that, it splutters a bit.
Also using a AS266 on a 30mm Delly on a stage 5 Mugello 225 with JL3.
Going through this because I've added a Ramair filter to keep the girlfriends leg dry and petrol free. :/
Any help would be appreciated
Bilko's Oily Blog
Splutters in what way? Does it splutter when you roll the throttle on gently and feed it, or just when you whack it wide open?
What main are you running?
Bilko
Main scooter: LI150
In between. When I open it up gently it's not too bad, but anything past that with a bit of welly and it's splutters.
132 main jet, but I didn't think the throttle was up past three quarters.
Bilko's Oily Blog
    Users browsing this forum: Google Adsense [Bot] and 0 guests
