without changing hub studs to fit the original innocenti split rim?mark wrote:You only need to change hub studs once and that's when fitting sip tubeless for the first time after that you can revert back to a std rim any time just using nylocks
what does these hub studs do and why cant the sip rim sit on regular studs?
