engine build
Ludo
Hi Guys any advice or thoughts would be appreciated.
Before i go and buy the wrong bits and give it to the guy whos going to build my engine, i have managed to obtain a 62 crank, 225Mugello kit, 28mmDellOrto but no exhaust at the mo.
I have a 200 Decent Indian Motor that can be used for the donor.
The question is will this combination work, what exhaust would work well and i assume from reading various bits and pieces that the crankcase mouth would have to be opened up. Is that right.?
As you can see i'm not an engine builder but advice would be welcomed.
Okay , over to the specialists
Cheers
Gaz
Speak to the man who is building your engine and take his advice then you know it's what you want
