barlow stage four set ups
C*NTSPEED
ebay user ID: sando1972
Tue Aug 16, 2011 4:39 pm
well folks what set ups are you running ie main jet and pipe also the timing am i right that they run around the 18 deg ?
GEMINI S.C.
BLACK WIDDA'S S.C.
H,POOL GADGE
Main scooter: vespa polini220/gts 300
Tue Aug 16, 2011 6:09 pm
1.7 packer - 12.5 squish - 14cc head volume - 123 main - 2.8 idle T5 slide cosa cap and carb supply hole drilled - 18 deg - augusta 6000 - jL R/hander
Tue Aug 16, 2011 6:33 pm
12.5 mm squish :shock: :lol:
H,POOL GADGE
Tue Aug 16, 2011 7:52 pm
give or take .5 then! ...what do ye think about lifting the top of the exhaust port 1mm gadge(sean) it would help lower compression, but would you have to rev the scoot harder to get it going....
Juan
Tue Aug 16, 2011 10:59 pm
Can the spark jump 12 mil then?
I'll hazard a guess the decimal point may have a slipped a point.
H,POOL GADGE
Tue Aug 16, 2011 11:05 pm
Ha Ha Ha! Oooops....1.25mm be no good at morse code would'a
C*NTSPEED
Wed Aug 24, 2011 7:07 pm
whats the recomended ring gap?
GEMINI S.C.
BLACK WIDDA'S S.C.
Wed Aug 24, 2011 7:15 pm
well i,d go for 0.3mm/0.35mm...but no doubt H/poolgadge would say 3.5mm :lol:
H,POOL GADGE
Wed Aug 24, 2011 8:50 pm
-.-- --- ..- .-- . .-.. .-.. --- ...- . .-. -.. ..- . .- ...- .. ... .. - -.-- --- ..- -. --. -- .- -. -.-. .... . . -.- -.-- .-.-.- .-.-.- .-.-.- laughing at an old man and his decimal points! work that out then......
Wed Aug 24, 2011 9:18 pm
