Exhausts joint clamp totally disappeard
Posted: Thu Jun 06, 2019 1:25 pm
by garry inglis
The exhaust clamp has snapped off somehow so changed break shoes and cleaned every thing while I was in there all done so whent for test ride
Re: Exhausts joint clamp totally disappeard
Posted: Fri Jun 07, 2019 7:58 am
by cgt75b
And was the scooter ok?
Posted: Fri Jun 07, 2019 8:08 am
by garry inglis
Yes I thought the db killer in the exhaust was loose coming back from kelso and when I checked the whole silencer was moving back and forward but luckily the water pump stopped it from going to far back to come apart all sorted now
Posted: Fri Jun 07, 2019 10:14 am
by cgt75b
Ah right ok, great that you've got it sorted.
I did lejog a number of years ago with lads on gts's and they were having problems back then with exhaust gaskets or slip joints I think,
Is this a common problem with them? You would of thought these kinds of recurring problems would be ironed out by the manufacturer.
Cgt75b.
