odd P2 clutch problem
tony172
Main scooter: vespa t5
I have recently rebuilt the clutch on my Malossi 210 and now have a problem. It works normally for the most part but, when in gear with the clutch in, I rev it up and it takes off as if I have let the clutch out!
At tickover its not creeping, at low revs it doesn't move- only when I rev it past around 4000k or so.
Its a 7 springer, Basket's in good nick,
medium weight springs (unchanged from before)
New Brass bush (SIP grooved type)
New Honda CR80 plates (soaked around 12hrs)
Oil drive cog installed behind clutch
New M12X1.5mm K-Nut
All other original parts re installed
I didn't have this problem before, so can only assume its either the Plates or the Bush (which did seem tight)
But with the bush being 4X the cost of the genuine one and SIP raving about the machining quality of it I'm unsure.
The Honda CR80 plates also seem to have rave reviews on the forums, and they slid in with no resistance.
Should I have soaked them longer?
Has anyone seen this problem before?
Tony
Ginch
Main scooter: Vespa 150 Super
Are the steels perfectly flat? Did you get plenty of separation when it was on the bench?
I just dribbled some oil on my CR80 plates and it was good to go.
tony172
Turned out that I had to put about 30 miles on the scooter due to the car dying and it's bedded in and is now the smoothest clutch I've used! I can only assume the new bush was the fault as it was tight.
Glad I didn't strip it straight away now as it's lovely.
Thanks for the reply though!
SUMMERS HERE BOYS!!!
Ginch
Glad to hear it! I love it when things fix themselves...
