Page 2 of 2
Re: Rear wheel changing on 1980 P200e...
Posted: Mon May 14, 2018 9:43 am
by paul d
In my experience if using a jack or any type of support under the engine to change a wheel, under the gear selector is the best place to support. It gives more wiggle room to work the wheel off if a standard exhaust is used. I think a tinny of your favorite tipple might be the right size too but I've never risked the loss of one! I read in an old lambretta manual that using the spare against the saddle while the scooter is on it's side is another tip but I've never tried it.
Posted: Tue May 15, 2018 8:56 pm
by timexit17
That rear light is the standard issue US one as they (the US DOT) felt the standard Italian/European one didn't give enough light rearwards.
Posted: Tue May 15, 2018 9:00 pm
by Grumpy225
rosscla wrote: ↑Sun May 13, 2018 10:28 pm
BTW Is that rear lamp common on Vespas over there?
Yes, that's a US DOT spec tail light. Common on P, Rally and I think Sprints from the early 70's on. Also seen on Spanish lambretta's.
They are big and ugly but you could hang your helmet off it if that helps
Posted: Wed May 16, 2018 10:23 pm
by rosscla
Yes, also on Jets and Lince Serveta. Easily broken off - if they're common in the States on more than scooters that might be another good source of fugly replacements for those of us that like that sort of thing
Posted: Thu Jul 26, 2018 2:00 am
by railfancwb
Just found a video about changing the rear wheel of classic 2-cycle Vespa.
https://youtu.be/H4o2vkzHzR8
