evening lads, can anybody give some advice on what bearings and seals i should fit to my 2012 px 125.
its just there are so many makes and types .
my set up will be bgm 177 top end, 26mm si carb 58mm maz crank and a jl pipe.
my current top end is/was a malossi 166 but my clutch side seal went on the way home from the southport vfm rally
vespa bearing and seal advice.
Any reputable bearings SKF, NRB, NSK, SIP, etc will be fine - for seals in my experience I use only Corteco and Yamabond them in.
