Scooter died
Holed piston, take plug out shine torch in to see it
- Main scooter: vespa px 125-180
Update on my dead scooter, so i've cleaned the jets changed the plug, HT lead, CDI unit and still nothing i get one little blurp and thats it, put petrol into chamber, nothing, i'm getting a spark so just can't understand why its not firing? Have i missed something? Oh and there's definitely getting fuel to the carb
Check the length of fuel pipe shorter the better does it run with choke on
if you`ve got good spark and fuel flow, you need the top end off.
Hi all
I've done all i can, think its time for someone who no's what they'er doing to have a look at it...think its something to do with the oil/fuel on back wheel?
Thanks for all your comments
- Main scooter: Lambretta LI 125 S3
My guess is a stuck/semi stuck piston ring. If you have access to a compression tester this will give you a clue.
