Hi Probaly a daft question but I think ive set up the speedo correctly does the fuel gauge show all white sections if full and each white section go out as it empties if you know what I mean
cheers steve
sip speedo fuel gauge
- smoore-gt225
- Main scooter: lambretta GT200
- Main scooter: Lambretta li150 special
No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
- smoore-gt225
thanks for reply but what was the point in incorporating a fuel gauge into the speedo than it says fuel gauge in instructionsTractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
I know the lammy ones flash
cheers steve
Sorry, I did not realize Vespa ones are a bit more high-tect.smoore-gt225 wrote:thanks for reply but what was the point in incorporating a fuel gauge into the speedo than it says fuel gauge in instructionsTractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
cheers steve
- smoore-gt225
I think theres a lot more room to fit everything in. ive emptied the tank now to fit a fast flow tap so I will check it as I refill and see what happens too the gaugesTractorman wrote:Sorry, I did not realize Vespa ones are a bit more high-tect.smoore-gt225 wrote:thanks for reply but what was the point in incorporating a fuel gauge into the speedo than it says fuel gauge in instructionsTractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
cheers steve
