My t 5 classic lurches forward when pulling away
Any ideas
T 5 clutch
They don't have a reverse gear if that's what your asking
- registered user
- Main scooter: Lambretta
- Contact:
Is it used regularly? If not it could be the clutch plates sticking together, then releasing suddenly causing the 'lurch'.jonboy wrote:My t 5 classic lurches forward when pulling away
Any ideas
Or, the plates could be worn and need replaced?
new plates fresh oil fresh inner cable sorted soak plates overnight in a plastic bag i find best
and check the turrets have no burrs on them
- registered user
- Contact:
A big part of this problem is the springs being done, change plates and springs together preferably piaggio genuine parts.
Otherwise buy complete new clutch unit plug and play.
good luck
good luck
