I like this already !!
2.5mm rings are standard P200 and still easily available no problem
Bit of blow past but cylinder bore looks in good nick - I`m sure you will be checking the bore wear before reassembly.
whats the intention with the ignition - change to PX electronic type or retain existing ?
Delving into VSE1M
Gaz, it runs really well as it is. No intention of swapping out the ignition until/ if it packs in. Good shout about piston to bore clearance. I was just planning on slapping in new rings and small end bearing :-0
FEMSA rules ................. Good luck with the maintenance matestorkfoot wrote:Gaz, it runs really well as it is. No intention of swapping out the ignition until/ if it packs in.
Must admit 66.4 is a strange starting point for a bore !!
You can be forgiven !!
I managed to find time to split the casings and have a look inside. So far, I don't think I have found anything to worry about.
The gearchange has been very precise and easy. However, the cruciform looks a bit worn. Should I replace?
Also, the Christmas tree, where it engages with the kickstart mechanism, there is a pronounced lip. I'm assuming this is normal and nothing to worry about?
Paul
The cruciform on the early gearbox is a weak point (compared to the stronger EFL type) - defo change it and as GL said use only a genuine one (wasp) and a cush drive repair kit. Dont worry about the lip on the xmas tree. More so check the loose kickstart cog/gear - change it if showing signs of rounding and the kickstart buffers.
Gaz
Gaz
