spark plug colour
crispin
Main scooter: vespretta chopper
hi
had trouble setting up my carb
just put new plug in and done about a mile on it plug now looks like this
got t5 engine with mb conversion now 175
28mm dellorto carb
60 slide
50 idle jet
x7 needle on top
125 main jet
timing spot on 16
idles fine
splutters a bit mid throttle
pic of my plug
scootcoot
i take it youv tried moving the needle clip down ? what atomiser are you using ?
am a doogal r u a doogal too....!
ducksta
digestive biscuit colour is my guide
Jack221
Main scooter: PX221
Crispin, You didn't mention the number of the atomiser (big brass bit the needle slides in and out of). With an X7 needle already on top clip (which should be lean already at mid throttle) I suggest you might have the wrong type of atomiser fitted. :?
crispin
Atomizer is av266
scootcoot
try av268 with the x7 on mid clip or x13 needle with av266 mid clip
goldeneye
mine is , Malossi 172, JL pipe, 28mm delly, av266, x2 top notch, 130 main, 40 slide, 70 choke , 55 pilot, mixture 2 turns out , 350 float needle jet, frame bellows fitted. starts first kick and runs clean except at below quarter tank when it splutters a bit at highish revs. SIP fast flow tap fitted as well.
Darrell Taylor
Main scooter: LAMBRETTA
the plug pic needs to show the base of the porcelain to see the colour
the plug porcelain looks very clean that suggests the grade might be too low ? what is the plug number ? 7
crispin
Br8es
goldeneye
a miles not a lot is it? give it a few mile . I don't like doing plug chops on fully synth oil either , as the plug doesn't colour up very well imo. I'm using Br9ex1 iridium spark plugs in all scoots now, cant fault them.
    Users browsing this forum: No registered users and 37 guests
