Page 6 of 8
Re: Malossi mhr 210 kit
Posted: Sun Mar 30, 2014 3:59 pm
by Jack221
Cominig on power at 5500rpm you would already need to redline 3rd to pull 4th. I think 126 degrees is about the road rideable limit for the PX200 gearbox(with t5 4th). Any more and you begin to lose too much bottom end pull. And as joked about earlier, with a longer duration than 126 the peak power on the dyno does increase but the scooter wont ride so well on the road, as the power band will be too narrow for a motor with only 4 gears.
And with 138/198 you would need to think about a 50 Special gearbox!
Posted: Sun Mar 30, 2014 4:25 pm
by santacama
Looks like the new exhaust are a magic wand (Nordspeed, Pipedeing, S & S, ....)
Posted: Fri Apr 04, 2014 5:24 pm
by Polossi220
Malossi mhr kit turned up looks nice
tried base gasket against casings not any different than previous kit ????
Tried base gasket against cylinder it doesn't match £300 on a new kit and they supply old stock base gaskets !!!!
Only in the world of scootering hahaha
Posted: Mon Apr 07, 2014 11:31 pm
by MattsDad
Please would someone just shut up!
This thread and many others; if want to feck up or compromise own engine then fine but keep posting this nonsense, others will believe it to be true!
Said it, been bugging me, not even had a drink!
Before you ask.....don't ask.
Posted: Tue Apr 08, 2014 7:32 am
by santacama
MattsDad wrote:Please would someone just shut up!
Since you didn't specify, could you please say who you are telling to shut up?
Thanks.
Posted: Tue Apr 08, 2014 7:56 pm
by 225worb
Cockspeed what part of the thread don't you agree with dude,
Looking forward to receiving my replacement Cylinder head by the way
Posted: Mon Apr 14, 2014 9:14 pm
by 225worb
Still no response... oh well !!!
Back to the point ,,,
Ive just replaced my water cooled cylinder head for a SIP item ..... F**k what a difference!!! Mine was modified to suite a Malossi cylinder but has had some battle scars and casting marks but the new billet one ive fitted has transformed my machine even more...
Ive managed to put some more miles on it and pretty happy with MY RUNNING in .....now for the fun to begin.....race anyone
Posted: Mon Apr 14, 2014 11:30 pm
by santacama
Is the SIP head water cooled too?
Do you have 60 or 57 crank?
Regards.
Posted: Tue Apr 15, 2014 9:00 pm
by 225worb
Yes it is... wasn't really looking for one as mine was doing the job BUT just happened to find one ..
Im running the serie pro reed crank and ive welded the big end pin just in case !!!!!!
Posted: Sat Apr 19, 2014 12:09 am
by santacama
Is it a 60 mm stroke crank?
