Forks
- Main scooter: SX230 TS1
New to Vespas,Got a PX mark 1 which has a 16mm trailing link and i wish to convert it to take a semi hydraulic disc brake set up (LML) hub looks the same as the early PX one thats fitted at the moment,Which is 22mm! now do i have to swop the forks out for Piaggio/LML 22mm forks or can i convert my old 16mm forks to take a new 22mm trailing link? Dont mind fettling just seems a shame to junk a set of forks which one are original to the scoot and two are as straight as an arrow. Help Please,Cheers
Anytime you have a 50-50 chance of getting something right, there`s a 90% probability you`ll get it wrong.
You can exchange the trailing link complete with axle.
The bearings don't come out easily as it's an interference fit, but a good vice should be able to push them out.
Always renew the bearings as well as the retaining cups.
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Nice one Fruitjuice ,So i take it is just the axle on the trailing link that is different, ie 16mm old type and 22mm on the newer type and not the fork leg its self So just to confirm all i need to do is buy a new 22mm trailing link and a new bearing set to match the new link and thats job done, Sweet,Thanks again.
mk1 and efl/disc/lml forks are different you cannot just change the lower link unless you have a remade pair of mk1 forks which are different to piaggio mk1 forks
Okay,so will a pair of LML forks(new ones) complete, fit into a PX mark 1 with on issues in regaurds to headset fitment etc:?: Cheers.Or what other type of forks will fit Thanks for your help.
i think the only issue you will have is with the steering lock as they are different in mk 1/lml but this is not a major issue you just need to weld up the old one and cut a new slot for the mk1 steering lock
Nice one,I can live with that,cheers for the help everyone this is a TOP site, And so the search begins :ninja:
- C*NTSPEED
- Main scooter: vespa ts 125/200
If you get stuck pal i got some 20mm forks here they just need a new pin pressing on to them the pins are about £20 then take them to any engineers to get the pin replaced
I can get a bit cheaper than that but if you pm tom wsp on here you can cut the ebay fees
GEMINI S.C.
BLACK WIDDA'S S.C.
BLACK WIDDA'S S.C.
hi try sip web site they do a semi hydraulic set up for a 16 trailing linkjunkyard wrote:New to Vespas,Got a PX mark 1 which has a 16mm trailing link and i wish to convert it to take a semi hydraulic disc brake set up (LML) hub looks the same as the early PX one thats fitted at the moment,Which is 22mm! now do i have to swop the forks out for Piaggio/LML 22mm forks or can i convert my old 16mm forks to take a new 22mm trailing link? Dont mind fettling just seems a shame to junk a set of forks which one are original to the scoot and two are as straight as an arrow. Help Please,Cheers
[img][/i
Disc Brake GRIMECA NT, for
Vespa PX -83 Classic,
Ø 16mm,
with PX MY brake disc and
caliper
£265.30
Art.No.30005000
Preview mg]
Cheers,
Had a look at these and was going to get a set but when i tryed they were out of stock for the 16mm type although they show as being in stock!! Ive managed to get a set of 20mm forks and a LML front disc so i should ave it sorted now cheers.
