coaster wrote:I believe that it applies to the curved measurement not the cord (straight line), you need to roll up a sheet of paper and tape insid the bore and then do a 'rubbing' with a pencil to get the outline to the port then roll it out flat and measure with a ruler.santacama wrote:If we say that an exhaust port should measure 65% of the diameter of the cylinder and we know that the diameter is 69 mm, so that 65% would be 44.85 mm. How do we measure these 44.85 mm? Directly in the cylinder in a straight line from side to side of the port? Or we draw the port on a paper and then curve the paper into the cylinder? There is a big difference
I've been doing a lot of this lately
i agree with this... you should do cylinder maping on it...
