Hi, when I click the switch down to have the headlight dipped it just goes off.
Very annoying for whoever I'm behind.
Any ideas?
Thanks.
PX Headlight Won't Dip
First thinvgs I would check ;
1. Bulb
2. Bulb holder - check connections, signs of corrosion etc
3. Switch wiring
Good luck
1. Bulb
3. Switch wiring
Good luck
- Main scooter: Vespa PX 125
So both bulbs are working.gaz_powell wrote: ↑Sun Dec 01, 2019 4:55 pmFirst thinvgs I would check ;
1. Bulb
3. Switch wiring
Good luck
Vespa operation manual says:
left switch on right handlebar...
1 (top pressed in) = Town lights
0 (switch to middle) = Lights off
2 (down pressed in) = Headlights
Right switch...
D (top pressed in) = High Beam
What i'm getting..
0 (switch to middle) = Town lights
2 (down pressed in) = Off
1 + D = High beam
I'm sure the lights were working right when i got the scooter at the start of summer.
For the time being i've gone for the quick fix of permanently dipping the headlight to the fullest using the bolt underneath the light. Seems to be low enough not to be dazzling other road users.
- ebay user ID: Lambretta67
- Main scooter: Lambretta L.I. 200 special
Are you sure the filament in the bulb hasn't blown . They are double filament. One for dip one for full beam.
I didn't know that. Will get another ordered and see if that works. Thank you.Lambretta67 wrote: ↑Tue Dec 10, 2019 8:58 pmAre you sure the filament in the bulb hasn't blown . They are double filament. One for dip one for full beam.
