Rb20 head gasket
sydduckett
Who is using one and whose not? Have had the metal ones on before but have quite a big squish. If i remove the gasket will this be to much?
Ta
sef
RinB
What do you call a big squish
And what thickness is gasket used
ArKaTxU
I am using the one that come with the kit and have a good squish.
I think that is of 1mm.
Bilko
Main scooter: LI150
Isn't 1mm a bit low?
I was led to believe you shouldn't go below 1.3mm.
Somebody will come along and correct me soon.
Bilko's Oily Blog
ArKaTxU
Bilko wrote:Isn't 1mm a bit low?
Yes, i want to say that the gasket is 1mm, not my squish :D
the lower the better,some bike engines cope with .8/.9 mm,but usually on smaller cc,s...
a lot depends on the expansion rates and con rod stretch ,but always get your squish to the min,
1.4 mm on a 72mm bore would be the max imo.
anything over that ,and the squish is not working.
http://scooterotica.org/forum/viewtopic.php?f=5&t=9439
sydduckett
Is there any where where you can get the correct squishes for specific kits? In my case an RB20. Im guessing it doesnt matter where you have the gaskets as long as the squish is correct. Could I do away with my head gasket by adding a thicker base gasket?
Ta
sydduckett wrote:Is there any where where you can get the correct squishes for specific kits? In my case an RB20. Im guessing it doesnt matter where you have the gaskets as long as the squish is correct. Could I do away with my head gasket by adding a thicker base gasket?
Ta
I run my stage 4 with double base and no head gasket with 1.2 squish but did use sealent on the top of the barrel...head was also tidied up by Sean..just re torqued the head after a few heat cycles..and it did need it...
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 63 guests
