PANEL LOCK MEASUREMENT
chippy
can any of you fine chaps tell me how far down from the top of the panel you drill the hole to fit a panel lock, thanks
yian-ts1
Chippy
What sort of lock you planning to use?
Will post my lock position tomorrow if it helps
chippy
yian-ts1 wrote:Chippy
thanks for that, intend using cam lock, with 20mm hole, seen the sterling ones, 27mm long. cheers
    Users browsing this forum: Ahrefs [Bot] and 94 guests
