thought I would try a pure copper gasket 3mm thick slightly extended to act as a heat sink
on the test one havent extended the sides like I intended too,
but they take more time than I thought they would mainly because I Need to make a better holding tool
also realised they need finishing by hand to suit the exhaust and pipe being used
then realised that I not really sure that it will work
opinions sought
one in picture still to be finished, got too cold in garage
thought it would be a good idea opinions sought
Silicone
use silicone myself but was thinking along the heatsink side reallyDJB wrote:Silicone
I would stick to a normal gasket. If its not broke?davidblythe wrote:use silicone myself but was thinking along the heatsink side reallyDJB wrote:Silicone
David - give it a go, what you got to lose?
Also did you see the thread about using the cylinder cowl as a heat shrink. I.E. using the stud extending connectors / nuts on all 4 head studs and drilling thru 3 new holes in the cylinder cowl.
yes I did and am trying out another daft idea along those linessoullad wrote:David - give it a go, what you got to lose?
if you use the cowling as a heat sink you could weld fins to the cowling underside letting the airflow under the scoot draw heat off?davidblythe wrote:yes I did and am trying out another daft idea along those lines
my mate is using one of these mounted to his exhaust stub. its from a triumph. no idea if it works or not but food for thought.
have a read of this ebay listing, very common on old brit ironrbgaz wrote:please someone tell me what its for/do else i want be able to sleep tonight !!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
