Why not mount a master cylinder behind the horncasing? I did on my series 2, and I think it looks far neater and you don't need to butcher the headset top! Just a thought.
jefo
series 2 hydraulic hose route
Much better idea than a hole in the headset.
I'll think of it next time.
http://lambrettiste.free.fr to get a FREE proper timing disc --> http://lambrettiste.free.fr/documents/f ... gradue.pdf
"A tidy shed is a sign of mental disorder"
thanks for all the replys so far,still looking for hose length (so wheel can be changed without to much grief )
allready got hydraulic switch housing mounted so want to keep that ( now the switch fits housing )
nice work that jason where did you get control rod from? would it work on series 2
many thanks fritz.
many thanks fritz.
- jason frost
- Dealer
Its just a standard rod cut a way to give some more room and I have done afew on S2s and it works fine.fritz wrote:thanks for all the replys so far,still looking for hose length (so wheel can be changed without to much grief )
many thanks fritz.
