Anyone had this problem? Just fitted a phbh Del 30mm and ram air filter set up on my GP and the filter elbow fouls the side panel so much that it forces the elbow into the carb. The carb is tight to the manifold and won't go in any further.
Bought this as a kit from camlam need to sort it before I take it for a dyno setup.
Any ideas?
Del 30mm
Usually its the manifold length that causes the problem, you might just check to see if Its been shortened enough.
i've got a similar set up with a mugello manifold,the elbow touches the panel but no problems.
where you taking it for dyno ?
- Arfur
- Playstation gamer tag: hulkascooby
Probably chisel speed it's the nearest to us in Sunny Scotland. The panel definatley forces the rubber into the carb it looks like there is room to move he manifold back but I would need to dril another hole in the manifold mount and I'm a bit reluctant to do that
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
Douggboy- OK who is it in the Avatar??
Scootering since 1968.
Look's like Kylie to me but it cant be, can it
its her
