Stuttering & four stroking
Smudge
Main scooter: Vespa GTS
You say at low revs so maybe your idle is too rich for the conditions, try dropping down a size and see what it is like. 10 minutes effort and you may be sorted.
Lambretta67
Main scooter: Lambretta L.I. 200 special
Thanks I will give that a go.
hat
Main scooter: SX150/ Mugello 186
Could try backing off on the mix screw a touch as well, maybe quarter to half a turn leaner
Lambretta67
I will try anything suggested
EddieStone
Have you checked your choke cable is adjusted properly? I adjust mine so there's a bit of slack in the cable when it's off. I'd check that as well, make sure the plunger is clean and closes properly.
Lambretta67
Would it still tick over if it wasn't adjusted properly. Because it ticks over fine. Was going to check scoot last Sunday but I pored down
EddieStone
Not enough slack, it seems. Bloody choke cable snapped at the nipple today!
Lambretta67
That's a bit of bad luck. Hoping for a dry weekend so I can sort my scoot out
Lambretta67
Took the scoot out today still ran badly but not as bad as the really hot day we had . Adjusted the mixture screw a quarter of a turn in & it runs fine now. Thanks everybody for all the advice .
hat
good news, thanks for letting us know. amazing how tiny alterations can make all the difference some times
    Users browsing this forum: Semrush [Bot] and 33 guests
