Damper gaiters.
Posted: Sat May 02, 2020 4:29 pm
by 10 inch Terror
Hi all, has anyone got rubber gaiters fitted to standard type dampers? I’ve got some MB ones I’m fitting to some slim type dampers. I’m struggling to see on which part of the dampers they should be fitted. Has anyone got a picture of theirs fitted please? Thanks in advance Pete.
Re: Damper gaiters.
Posted: Sat May 02, 2020 7:26 pm
by gaz_powell
http://www.discodezscooters.co.uk/p/lam ... p_li_1_2_3
I can't post a picture of mine - but they are just like these
Re: Damper gaiters.
Posted: Sat May 02, 2020 7:28 pm
by Lambretta67
Yep . That's how mine fit
Re: Damper gaiters.
Posted: Sat May 02, 2020 8:41 pm
by 10 inch Terror
I tried fitting them like that, but the gaiter just slides back up the damper. I’m not too impressed with them tbh. £25 and they look like a bag of spuds.
Re: Damper gaiters.
Posted: Sat May 02, 2020 10:09 pm
by gaz_powell
Sounds like you've got the bigger ones for standard size and not the ones for slimline dampers.
Re: Damper gaiters.
Posted: Sun May 03, 2020 5:36 am
by 10 inch Terror
gaz_powell wrote: ↑Sat May 02, 2020 10:09 pm
When I ordered them the description said for slim type dampers. The dampers are the Scootopia re made ones. I’ll do some investigations today. Cheers mate.
Re: Damper gaiters.
Posted: Sun May 03, 2020 7:47 am
by db67
Return them for a refund & source some from another dealer
Re: Damper gaiters.
Posted: Mon May 04, 2020 5:54 am
by 10 inch Terror
Turns out I need the ‘Fat’ dampers. I ordered the ‘slim’ type...doh!
Re: Damper gaiters.
Posted: Mon May 04, 2020 6:56 pm
by gaz_powell
Im after a pair of used slim ones for my dampers......if MB won't swap them !
