The earlier TS185 piston can be used, if you're prepared to relocate the top ring peg. I've had it done before, and it's still going strong several thousand klicks later, but easier to just use the later 'ER' piston, which is identifiable by cut-aways around the gudgeon/wrist pin.
TS185-ER piston part number is 12110-29900. The 'ER' gudgeon/wrist pin is 12151-78110 (this part number has been superseded by 12151-60D00). The 'ER' pins are 16x49.5mm (non-ER types are longer at ~53.5mm). I've also been informed that Wiseco part number S255, should fit, but have no experience. The Wiseco is 16x49.9mm.
