Motoplat ignition coil
kevspeed
Hi all,just a quick one...
Is there a direct replacement for the 6v Motoplat ignition coil,or am i going to have to source one?
Thanks....Kev
garry inglis
I've just stripped an original Italian gp with a 6v system and I got it running before I stripped it and the coil works fine so if you get stuck let me no
Sent from my SM-G960F using Tapatalk
kevspeed
Hi Gary, thanks for the offer, I'm not sure that my Motoplat stator will work with a GP coil, I'm trying to find out.
garry inglis
I see what you mean kev I've just had a look at them mines the normal tube like coil I would have thought 6v is 6v
garry inglis
Scooter restoration ImageImageImage
Warkton Tornado No.1
Main scooter: Lambretta SX200
kevspeed wrote: Sun Dec 01, 2019 6:36 pm Hi all,just a quick one...
Thanks....Kev
In my experience, the Motoplat coils, & replacements designed specifically for them, will work on the race systems or Serveta set-ups. The ignition system is independent of the supply for lights/battery, so don't get confused by six or 12 volt variations as they have no effect.
Somewhere, I have an Ital CDI that looks completely different to the OEM types, but fits as per original & works well.
In fact, the point I am trying to get to, is that I would suggest you seek out the type with the additional connection to feed a tachometer. Motoplat tachometers are identical to Krober, which you may be aware have an excellent reputation.
The problem will be finding a used one that doesn't start it's scale @ less than about 4000 RPM, but new ones are available via HOI etc.
I hope that information helps........ :x
kevspeed
8-) Thanks WT, more info to keep in mind 8-)
Gazjet1
Is it the electronic one or points one you need?
kevspeed
Points type
kevspeed wrote: Wed Dec 04, 2019 4:18 pmPoints type
Oops! :oops:
My mistake in presuming that you had an electronic set up.
IMHO that is a good thing as, despite the World & his wife changing to electronic for "reliability" a well set up points system will prove itself more durable & can be easier to fix, should it go wrong......
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 60 guests
